Beta Rev 3 Wont Start After Replacing Throttle Cable
Hi guys. As above in the title. I recently replaced the throttle cable on my 2004 beta rev 3 250 and now it wont start. Before i changed to throttle cable it started first kick everytime. If anyone can help. It will be much appreciated :)
Put everything back as it was. Throttle feels fine. Got it started once after messing with throttle adjustment but died after taking choke off and wont start again now. Could be something simple like not enough fuel in the tank lol. Will check that later when i get some 2 stroke. Thanks for the reply
This sounds like blocked pilot jet.
It'll run on choke, but as soon as it's closed it can't draw fuel up the pilot jet due to the blockage so stalls.
Clean the carb (and jets) out and try again.
You have the slide in wrong or the wrong cable. You should be able to hear the slide hit bottom when released from full throttle. Good luck.
Hearing it hit bottom IS important! A must! If you have anything out of place you need to check, cause it is like trying to start the bike with the throttle open.
