November 4, 201412 yr Hi Guys, I had a problem with clutch fulid leaking from the front sprocket shaft...... so after doing other work on the engine I decided to replace the seal (retain seal).... but I replaced this and its loose now and seems like some thing is missing??? I thought that once I replaced the retain seal that was the job done! nope there another part to it a shift seal bushing and 2 rubber o rings..... I put the old ones of these back again but they just fall down the gear shaft and dont seem to stay up beside the retain seal...... any ideas?? cheers
November 5, 201412 yr There should be (from out to in) a circlip, the sprocket, bushing, o ring 1.5mm o ring 2mm. From the inside this falls into the 2nd gear and its selector and 2 half neadle bearings. How did you replace the parts? Edited November 5, 201412 yr by crazybond700
