November 15, 201411 yr Engine been in bits and Kick start sticks dosnt return. When i loosen 3 bolts nearist shaft on casing it works fine. My sugestion is 2 gaskets. Or have i put something in wrong???
November 15, 201411 yr kickstart spring has just needs slotted back into place on kickstart shaft, it's tricky to see as it's behind the washer on shaft. had same happen to me
November 16, 201411 yr Author Been told i lost a washer that goes on end of shaft that casing pushes up to? Were can i find a parts diagram
November 16, 201411 yr download the 2001 parts manual from here, http://www.trialspartsusa.com/GASGASmanuals.html and this may be the washer you need http://trialstribulations.net/index.php?main_page=product_info&cPath=29_63&products_id=1952 hope this helps.
November 16, 201411 yr Author Sorted it, was aluminium washer not correctly down on shaft, thanks simon
