dibs Posted January 1, 2015 Share Posted January 1, 2015 Hi ime just building the bike up and wondering if there should be rear tank fixings or does it just have fixings at the front and the seat holds it in place at rear, can't see any place for rear tank rubbers / fixings regards mark Quote Link to comment Share on other sites More sharing options...
pschrauber Posted January 1, 2015 Share Posted January 1, 2015 The tank is attached to the side at the rear by two rubber bushes that are mounted to a smaller tube beneath the central frame tube. The tank should have a rubber cushion of high density foam rubber between tank and frame, then will be hold by the seat. Quote Link to comment Share on other sites More sharing options...
