January 17, 201511 yr Hi does any one know if it is a normal are backwards thread on the clutch as I am having trouble undoing it thanks
January 20, 201511 yr Its a standard thread on the centre bolt that holds the clutch, I take it you have already modified a socket to fit it. I always undo them with an air gun and hold the centre with some grips and thick cardboard to avoid damaging the teeth. Just be careful how you do it, Thats the most important thing. It might be a good idea to medium strength thread lock the nut when re assembling. How come you are removing the clutch? You can strip out the clutch plates without undoing the centre nut, Unless you are removing it to split the cases.
