January 22, 201511 yr After finding it difficult to get a rear mudguard for this bike. I've head you can change the sub frame to a newer model and then use that mudguard. Does anyone have any info on this like what parts I need get etc
January 22, 201511 yr the subframe is only 2 brackets if needed, and i think the only difference is the air box if its a 2000 you gain access through the side but later ones you go through the seat panel so you would prob need an air box as well unless you can trim the later one to suit yours
January 22, 201511 yr Author Right so Id need get the new airbox And the new brackets, which brackets are they exactly?
