2014 Evo Airbox
Hi all! Is anyone with a 2014 evo have any problems with water allways in bottomn of air box? And as anyone found a better way to route fuel pipe from tap to stop it kinking?
Problem with fuel hose is that it goes forward between cyl head and lower side of frame through cyl support bracket then loops back on its self down to carb! It seems to kink here and its pretty near cyl! looking at 2015 parts diagram and that seems to have a different tap!
Yes, after many years of having leaky fuel taps it seems for 2015 Beta have decided to try something different.
The reason the taps leak is slightly rough finish on the metal tap parts. It prevents the seals / O rings sealing. Polish off the roughness and the taps work OK.
I have not looked at a 2014 air box but pretty well all previous Betas need extra sealing work to minimise water ingress into air box.
Edited by dadof2
Put a 90 degree fitting about an inch past the petcock. No more kinks.
