Beta Rev 50 Clutch / Rear Disc
Is there any way of making clutch lighter. Ie different lever, oil type or mods. Also rear disc don't linr up in middle of calliper. Think its spacer to long which has worn disc bad, what size fits as its 17 inch wheel. Thanks
  • 2 weeks later...
I was looking for an old post of mine and I came across this one.
Can't help about the disc, but it could be a warn space, or spacers in the wrong way around; i.e. left side on right side and right on left. It could also be a missing washer. You can download the parts list from Beta UK, this might give a clue if there is anything missing.
http://www.beta-uk.com/index.php/downloads
I can answer the clutch question. I did the Beta Clutch fix:
http://www.trialscentral.com/forums/topic/28407-the-beta-clutch-fix/
On my lads Beta 50. It took quite a while, but I was able to take out half the springs without any consequences and it made the clutch much lighter.
I also use Putline Light Gear Oil and replace it very regularly to make sure that it's still effective..
