March 3, 201511 yr HI T T, try heating up the right size flat blade screwdriver and melt a slot in the end, might work?. Take the required precautions re heat in the fuel area tho. Cheers Taff
March 4, 201511 yr Author Thanks taffy. I gave the idea a go, and was moderately successful, but the slot kept on breaking. Then I did a silly thing and tried to drill it out. Long story short - heli-coil insert to the rescue. Edited March 4, 201511 yr by trialtrial
March 4, 201511 yr Hmmm, I should have realised that if the screw was stuck firm enough to break in the first place then the slot would also break, glad you got it solved tho. Cheers Taff
