April 19, 201511 yr Do you folks think I'd be wise to mod my frame (aka drill & chamfer a hole ) for my clutch pipe and throttle cable as Bill Pye did to this one he built ? The 97 section has no fork stops , except for o-rings on the fork down tubes and they tend to pinch the clutch pipe and throttle cable at full lock with the stock routing ... The one little hole would be easy to do and makes sense to me before I install a new clutch pipe ... It is routed to the top of the radiator guard thru a notch that it doesn't stay in , this makes for a much more natural , relaxed path ... Bill's bike ; http://www.nickandkaren.co.uk/frankfieldfantic.co.uk/Mono%20shock%20special%201.jpg And Mine will look slicker than that when done . (I hope ) Glenn
April 20, 201511 yr Improved function, less failure opportunity, combined with better look... Here is the true sign. If you excitedly tell a Mrs what your thinking and her eyes glaze over. Its a no brainer. Go for it! --biff
