April 27, 201511 yr can anyone tell me if the tr32/34 has 3 wires from stator to cdi 1 blue 1 black and 1 grey ,if so what cdi does it use
April 27, 201511 yr pretty sure they use motoplat if so there is no cdi as such its built into the coil the blue wire goes to the larger spade on the coil and the black wire goes to the smaller one and the kill switch earths out the blue wire the grey wire would be for lighting
April 27, 201511 yr Author it is motoplat , you could be right , its actually on a cota engine but not what i am used to bike has 2 blue 1 black 1 grey which go to a cdi , the one i now have only has 1 blue 1 grey and 1 black , i have seen a stator from a tr which only had 2 wires which would probably go straight to coil ,could be barking up wrong tree
April 27, 201511 yr Author thanks for that , its not same as mine so it must be from a cota believed to be from a 309 but cant find a wiring diagram or pic of cdi
December 12, 20205 yr On 4/28/2015 at 12:01 AM, pschrauber said: Here you are, Motoplat is the ignition for the TR: Sorry for digging out an old topic, but I'm somehow not able to send you a private message. Do you by any chance have more of those Repair Manual photos for TR34?
