June 7, 201511 yr Hi guys n gals I'm after a little advice I have had and still have Bultaco Sherpas for many years now, I am going to View a Fantic 200 with the forward kick engine, any help on what to look for would be greatly appreciated Many thanks Steve
June 7, 201511 yr Cracks in the reinforcement webbing at the headstock Clearance between the frame lower rails and the engine Broken tops to the ally fork legs where people have used levers to replace the fork seals Broken air box lugs Worn kickstart lever joint
June 7, 201511 yr ...condition of Carb intake rubbers between airbox and carb and carb to engine If HT coil has been replaced with modern CDi type That the correct top yoke is still fitted Search the internet on 200's with rear kick and 200/240 forward kick bikes - a French site is very good just use Google translate. http://www.fanticmotor.asso.fr/r02.htm Edited June 7, 201511 yr by bishyfishy
June 8, 201511 yr If it moves under it's own power , buy it ! 200 pros are the bomb ! You can fix most all issue's easily !
