skippy1234 Posted June 19, 2015 Share Posted June 19, 2015 (edited) hi all,can anyone give the best advice on how to get the needle bearing out of the crankcase where the gear change drum sits into,thanks Edited June 19, 2015 by skippy1234 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted June 19, 2015 Share Posted June 19, 2015 Break the rollers and any cage out with a screwdriver or similar. Get a bolt (correctly called a screw as you need it threaded all the way to the head) the head of which just fits inside the bearing. Put the head into the bearing. Then you need a washer that is a larger diameter than than the inside of the lip on the bearing race. Cut the washer in half then hook the halves under the lip on the bearing housing. Tighten a nut down the threads to lock the washer halves in place. You can the pull on the bolt with slide hammer or similar. Quote Link to comment Share on other sites More sharing options...
