Fantic 309 Frame Repair
I have a crack in the frame that needs welded. Is it safe to weld with the stator and other ignition components still attached to the bike or do I need to remove them? The crack is in the weld at the downtube / headstock joint.
I think the question is will the ignition suffer due to the welding not will the weld work.
To be safe I would always remove electrical components if using an electric welder, far cheaper to be safe than sorry.
If you can get the earth clamp from the welder next to the weld it's safe,but if not remove the electrics
