August 3, 201511 yr Hi, Dose anyone know what the Big end float should be for a 2003 125cc rev 3 please.
August 4, 201511 yr Ah, ah you mean clearance, wink, slop, free play, je suis savant! Edited August 4, 201511 yr by billyt
August 4, 201511 yr Author Yes I have replaced the Connecting rod ,but there seems a lot of end float, dose anyone know what the free play should be
August 5, 201511 yr I have always done my cranks at 18 thousands. Beta only gives a spec for the two halves total distance. 62 mm: +0.05 to -0.15 mm. I always looked at float being play in the whole shaft. Rod set up was a different manner. That is Beta specs from the manual.
