September 8, 201511 yr Hello can any 1 tell me if the kick start rachet stopper on my 199b is it different to any other?reason i ask is am rebuilding my Engine and noticed it was worn i have some spare but are abit shorter in lenth they do fit the only difference i can see is the hook bit that keeps the rachet in place is abit wider i need to know before i build it so any help would be good.
September 9, 201511 yr My parts book tells me that it is the same for 350 models 159, 183 and 191 and also for 250 models 158, 182, 190. The Bultaco part number is 23.12.007, crank stop. Part 4 on the pdf attached. I only have the manual for 5 speed models 1967 and on. Hope this helps. Nov 14th.pdf
September 9, 201511 yr Author Hello 1973tr6 thank you for your input i can't see any differents regarding the complete kick startshaft and rachet mechanism on my 199b to my 199A witch i not long rebuilt i also have a 198A witch is apart and the stop Arm is same as the spare 1 i have the end off the stopper is slighly thicker and the the lenth abit shorter any way thank you anymore help would be wellcome.
