October 20, 201511 yr Anyone else experienced an occasional clunk of the headset and sorted it.. bearings smooth, top nut tight, clamp tight..? clunk occurs when putting front end down to earth, not every time, certain its from the headset not the forks. few clues before I strip it out may help Cheers
October 20, 201511 yr http://www.trialscentral.com/forums/topic/51154-front-end-clunk-sort-of/?fromsearch=1
October 21, 201511 yr Hmmm I just bought sheets of PTFE to use as optical diffusers for work. Maybe I should try to see if I can make a shim out of the .005 sheet.
October 21, 201511 yr Check the outer races of the bearings are not loose in the frame. If they are stick them in with the right grade of Loctite. If this does not work a run of weld around the outside of the frame where the races fit will shrink the tube and tighten them up. Remove the races before welding. A decent thickness of TIG weld deposit is needed.
October 21, 201511 yr Author Thanks fellas Last EVO and REV3 had no issues Sounds like I need to get the old PTFE out Presume you know the abbreviation means - Plumbers Tape For Everything! Cheers
