November 6, 201510 yr US supplier has no replacement bearings for rear suspension dog bones. Does anyone know if the OEM DL1512 bearings are the same size as HK1520-2rs bearings?
November 6, 201510 yr Author Thanks Reggie. FYI, I have located a source for HK1512 bearings which will replace the OEM DL1512 bearings. IBT PO Box 873065 Kansas City, MO 64187 Tel, 913-677-3151 Fax 913-677-5510 I picked up four HK1512 bearings from their local branch shop, cost $9.00 each. The HK1512 bearings are caged roller bearings unlike the OEM DL1512 bearings. Also the rollers in these bearings do not have the pointy tips which eat through the bearing case like the OEM IBT also offers the HK 1520-2rs which will work for the newer GG bikes.
November 9, 201510 yr Agreed. Use the HK1520-2rs bearings and then you don't need the OEM type seals (which leak and fall out). The dog bones are 20mm wide. You will probably still need to source the inner rings (bushes) as a Gas Gas part as most bearing suppliers don't sell them. Gas Gas part numbers are BT27712014 (20x15x8mm) 2 required and BT27712005 (20x15x10) 2 required.This only applies to the four dog bone bearings. There's another two in the underside of the swing arm with two 3mm wide seals. You can't use the HK1520-2RS in there as the total width will be too wide (40mm vs 38mm total). But those bearings a well protected and don't give as much trouble. Chris.
November 12, 201510 yr VXB bearings has everything you wold ever need. I get all of my suspension and wheel bearings from them including the spherical bearings. --Biff
November 13, 201510 yr VXB bearings has everything you wold ever need. I get all of my suspension and wheel bearings from them including the spherical bearings. --Biff I've been using VXB for years , For all sorts of projects . If you have accurate dimensions , you can find just about any type of bearing there is , and the prices are quite fair too ... Glenn
November 13, 201510 yr All Balls also has the kits for Gas Gas. They are complete kits, include the bearings and bushings for the bottom of the swing arm and the dog bones. Here is the link. http://www.allballsracing.com/27-1154.html Brian
