Machining Your Own Parts
It's a pleasure for me work on my mini lathe. Sometimes I gave my motorcycles  a gift.
  • Replies 47
  • Views 28k
Most Popular Posts
  • New Sherco gas cap to replace that cheap one
  • Wheel bearing extractor http://www.homemadetools.net/forum/motorcycle-wheel-bearing-remover-65091#post103242
  • Good design and machining Cascao.    I had trouble with my 2015 Beta 300.  I have small feet and it kept slipping off the rear brake pedal. I solved the issue by re-designing a slightly wider rear
CAM01372
CAM01369
CAM01368
CAM01366
Edited by cascao
I solved the issue by re-designing a slightly wider rear brake pedal platform and installing some pins. Problem solved.
Edited by billyt
Hey Billy, looks good! Not to worry about he small feet mate, you are proportionately correct......matches the short arms....and deep pockets...its Scottish thing I am told. ha ha!
Billy, can you use a pair of Gaerne size 6 US? I need to move them out as they were my wifes.
Anyone?
  • 3 weeks later...
Throttle wheel with bearing
CAM01400
Modified stem nut
CAM01389
Lever frre play bolt
CAM01382
Keihin glove adjustable idler bolt
CAM01381
Edited by cascao
  • 3 weeks later...
In need of more ideas to "improve" my bike
Rainy weekend....
Forks rebound no tool adjusters.
  • 3 weeks later...
Bar ends
An often overlooked option that is very important! Specially the throttle side!
