December 5, 20178 yr Author Wheel bearing extractor http://www.homemadetools.net/forum/motorcycle-wheel-bearing-remover-65091#post103242
January 10, 20188 yr Author Made months ago steel footpegs. This ones are larger than originals and really stand all the abuse.
November 16, 20188 yr Author Fan skirrel noise and a greath ride scheduled for tomorrow.... Made new motor buschings and it is like new now
November 20, 20188 yr On 8/1/2016 at 2:28 PM, cascao said: Bolt seizure prevention. O ring on triple clamp gaps. Excellent idea ?
December 10, 20187 yr Author Grips cutter to convert MX grips in trials ones since it is hard to find in this part of world https://www.flickr.com/photos/cascao/31326703027/in/dateposted-public/
January 1, 20197 yr 13 hours ago, cascao said: Fixed some dents on pipe using air pressure and heat what pressure works?
January 1, 20197 yr Author 2 hours ago, nigel dabster said: what pressure works? 90 psi and turn the part you want to fix red hot with a torch.....use a pressure regulator to maintain pressure constant since it tend to increase when you heat the carbon inside (burn most you can before), use thick gloves, face shield and all proctetive equipment you have since it is something dangerous.
March 31, 20197 yr Author New gas cap https://youtu.be/vovRknQiFCc Edited March 31, 20197 yr by cascao
April 1, 20197 yr On 7/31/2017 at 1:54 PM, cascao said: GPS Garmin Etrex case + vibration dampening mount. think thats called a testicle remover.
