November 29, 201510 yr hi im rremoving the engine from my 03 sy250 and ive gotten as far as removing the rear swing arm bolt but it will not budge any tips? and if i use force to get it out is there anything i need to be careful of breaking or damaging?
November 29, 201510 yr Have you slackened the other engine bolts? and sump guard? If the engine is running / bike rideable put plenty of penetrating oil at the bolt ends and where swing arm meets crankcases and then ride the bike about a bit. If it still won't move get the bike to a garage with a hydraulic press. Properly support the frame round the bolt head with a bit of pipe whilst pressing it. If it feels too much pressure is being applied and its still not shifting try warming the back of the crank case with a gas torch. If the bolt rotates but wont push out it is the inner parts of the swinging arm bearings that are stuck / rusted to it. If necessary drill the bolt out, its a lot cheaper to replace the bolt than replace a damaged swing arm or crankcases.
November 29, 201510 yr I've used an electric heat gun for the same job, heated and cooled a few times before a final heat then tapping out bolt when still hot
November 29, 201510 yr Author Thanks! I ended up getting a length of rod and a lump hammer and just hammering it it took a lot of sweat and a few broken knuckles but its out
