iltakeafive Posted December 22, 2015 Share Posted December 22, 2015 Hi, could anyone tell me a good set up for sidecar trials? How much difference between solo and outfit sprocket sizes? Cheers Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted December 22, 2015 Share Posted December 22, 2015 (edited) On my Beta Evo 300 outfit I use a 11/42 set up that is about what most solo riders around here use. Looking at the Talon Engineering web site http://finder.talon-eng.co.uk/products/tg376520/?tpf_manufacturer=35&tpf_model=430&tpf_year=1639&bikes_category=front-sprockets&bikes_subcategory=standard they do a 43 tooth 520 pitch rear sprocket and fronts from 10 up to 14 teeth for the RL325. So try 12/43 and see how you get on. If you find it over geared you can always drop down to a 10 tooth front and take a link out of the chain if need be. Edited December 22, 2015 by p@ul250 Quote Link to comment Share on other sites More sharing options...
iltakeafive Posted December 26, 2015 Author Share Posted December 26, 2015 Cheers Paul great help ☺ bit off topic but do you use motocross bars or trials bars? These seem really small length wise and and are far forward unlike the new renthals I have. Cheers Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted December 28, 2015 Share Posted December 28, 2015 For a bike like the Beamish you'll need Renthal 7/8" trials bars. Either 735-01 which have a 5.5 inch rise or 735-02 which have a 6 inch rise(dependent on how tall you are). A lot of sidecar drivers will cut a lot of length off the right hand side of the bar to give more clearance for trees and other such things. On my own outfit the right hand side has been cut down by an inch & a half. On the left I have one and one half grips fitted so that I can move my hand in towards the centre when turning right or needing to get my weight over to the right. I hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
