Rear Brake Bushing Nut
Bent my rear brake lever the other day. Also broke the rear lever bushing nut. Ordered one thru lewissport but apparently it's back ordered. Does anyone know of a suitable replacement? 15 Evo 250
Thanks
can ya find another nut with the same dia/thread count that ya need and grind it down to the appropriate thickness to work? - just a thought - don't know if it will help or not - good luck!!!
Thanks just need the nut which is propriety. It serves as the race for the pedal as well as nut and threaded for the 8mm bolt. The parts diagraphm has a picture. I have extra levers already.
Old
Yes 3, most dealers don't actually stock parts, they just carry the usual break away parts(levers, brake pads etc) and maintanence items. They usually order from Betausa.
Easy to make one on a lathe.Any small engineering co.could make you one,which might be quicker than waiting for one to be sent to you
