January 24, 201610 yr Has it just started doing it or have you just bought it, some people wire them directly to run constantly if they have had problems
January 25, 201610 yr Fan switch, also called a thermostat! Or could be a damaged wire shorting and letting the fan run constant.
January 25, 201610 yr Take out the thermo switch and check it with a multimeter, if there is continuity between the terminals then that will be the problem, in fact just leave it in place but disconnect the wires then check across the terminals (on a cold engine)! Edited January 25, 201610 yr by mspenz
