February 12, 201610 yr Got a beta evo 2014 250 for my birthday and need to buy some gearbox oil but dont know the best one to buy anyone recommend any? would be much appreciated.
February 13, 201610 yr I'm another one using Nano Trans. I've been struggling to get a good clutch action on my 2014 300. It seems to suffer lots of drag, no matter what oil is in there. Cleaning the plates helps, see post at top of the Beta section, as does the Nano Trans. But I'm going to try some of these different setting by replacing the thicker inner and outer fibre clutch plates. http://www.betausa.com/sites/default/files/pdf/STT-2012-3-Evo%20300%20clutch%20set%20up.pdf
February 13, 201610 yr I tried 3 or 4 and settled on Motul 300v. Less drag and smoother release. Although fitting a sureflex clutch pack made a bigger difference than; changing the oil brand, swapping out the thicker plates, or doing the clutch fix.
February 15, 201610 yr ATF mineral based works best for me , changed regular Have also done the clutch mod and my clutch is spot on
