February 15, 201610 yr Hi all I picked up a neat Evo 290 on the weekend ( will be getting a slow throttle for it). The previous owner says it is a 2009 model, but it has a black frame and plastics which would indicate it is a 2011 model. Can anyone confirm what it is for me please? image is attached
February 15, 201610 yr Model range here but could have had frame changed because 2009 frame used to crack and the rad filler comes out of the side of the frame.2010 on came out central front between the front frame rails.http://www.betausa.com/node/751 Edited February 15, 201610 yr by bilks
February 15, 201610 yr Author Thanks Bilks. The wheels and radiators leading me to believe it is a 2009 model
February 15, 201610 yr The rear wheel is the earlier 2009/10 type, also the rad filler as Bilks said. I know the rear subframe mounts also changed on later models and this looks like the single bolt early type
February 15, 201610 yr Is the fuel filler slightly offset to the leaft,and radiator filler placed where your leaft knee will smack it!!! 2009
February 15, 201610 yr I had an early 09, the petrol filler was offset to the left. A friend bought a late 09 and his had a bare aluminium frame with the filler mounted vertically. Your frame could have be an 09 that has been coated
February 16, 201610 yr Author Got hold of the importer. He confirms it is an '09. Thanks for the help
