March 6, 201610 yr Hey guys , im having problems with the back brake, It started to squeak when freewheeling , the pads seem OK and I've replaced the cylinder kit but it still no good , it will lock up but you have to press it hard , I've had it into a garage and they did the cylinder repair so they bled the system and cleaned it all out but still no good , I've ordered some galfer pads but don't really know what else to do so any help would be good cheers fellas
March 6, 201610 yr Sticky piston in the calliper.. Pump them out clean them with fine emery.. And calliper, replace and BACK bleed the system
March 6, 201610 yr Author That sounds spot on matey I'm a bit of a amateur but I think I know what ya mean haha cheers fella ???
March 6, 201610 yr Get the disc very hot (almost smoking ) by riding with it on and then tip a gallon of cold water over the disc...................job done
March 6, 201610 yr Get the disc very hot (almost smoking ) by riding with it on and then tip a gallon of cold water over the disc...................job done ?? Why that's crazy!
March 6, 201610 yr Author Yep I've heard the water trick somewhere before I'll give it a whirl cheers guys
March 7, 201610 yr In other words bosh it till it works! Do yourself a favour pal , strip it clean it , free it off and save yourself some more greif later on Edited March 7, 201610 yr by lockie28
March 7, 201610 yr Author Haha I've heard on here about the water thing it is something to do with some sort of chemical reaction that happens , but I will try cleaning it all out and back bleed it , hopefully do the trick cheers matey ??
March 17, 201610 yr In other words bosh it till it works! Do yourself a favour pal , strip it clean it , free it off and save yourself some more greif later on First time I saw the water trick was when a former (Tommi)World Champion took a brand new bike out of the box. First thing he did after starting was the water trick. I have been using it ever since.
