March 30, 201610 yr I have some clear film to help protect the frame and swingarm, but I need to cut out the suitable shapes. To help me with this, does anyone have templates for these shapes that I could download, or even if you still have the backing paper in the right shape, left over from some already installed. I'd like to cover up both sides of the frame and S/A, so any/all of those shapes would be most helpful.
March 30, 201610 yr Tracing paper & pencil will do Tape the tracing paper to the frame part with masking tape & shade away Blue Peter tip
March 31, 201610 yr Author Tracing paper and pencil will do Tape the tracing paper to the frame part with masking tape and shade away Blue Peter tip Yes of course, but that's the last resort. It would be much easier if I had some sort of pre-made template. I'm sure someone somewhere has the backing paper they pulled off a sticker kit when fitted, or even better a graphic file of the shape in DXF, EPS or PDF etc format that I could print and cut from. Failing that, I'll probably draw my own on the computer, but would prefer to save the time if anyone can help.
March 31, 201610 yr I've only got the frame stickers: Frame stickers 4RT_0001.pdf Frame stickers 4RT.pdf
March 31, 201610 yr Author I've only got the frame stickers: ... Fantastic, thanks. EXACTLY what I was hoping for. Brilliant. Thanks again. Don't have the same for the swingarm do you?
