April 1, 201610 yr Hi guys I have a 2013 txt pro 300 the issue I'm having is I'm going through spark plugs like every month and when I take them out they are full of carbon. I was wandering if the carb is set up right as I'm running the fuel oil mixture to what gasgas recommend and can o my think that the carb is dragging in to much fuel?? Any help would be great thanks
April 1, 201610 yr Author Yea air filter is fine bike always runs fine when I'm using it then dies out won't kick back up until I change plug
April 1, 201610 yr If it comes out really black or your mixture is too rich, too much oil, bad ignition (but you should notice this) Edited April 1, 201610 yr by crazybond700
April 1, 201610 yr Cold start enrichment system (often called choke), float valve and float level would be my first checks, after air filter. What grade of plug? What oil ratio and what type of oil?
April 2, 201610 yr Cold start enrichment system lever position sometimes can be the problem if this bike is new to you. It has to sit just right or it is partially open.
April 5, 201610 yr Yes, its sounds like it is running too rich. In addition to previous suggestions, check your low speed mixture screw. In most carbs it is an air screw so turning the screw out would make the mixture more lean. I think Del Orto uses a fuel screw so turning the screw out will make more rich. FYI, I always carry a spare plug and tool to change it along the trail. Yes, even with my 4RT.
