April 26, 201610 yr Might have a slight weep on the m cyl but its part of the formula set up. No name on cyl so are they interchangeable? Seen a new one for £60 rather than do seals piston etc.Any help appreciated.
April 27, 201610 yr I would say yes, why not, but I havent tried. Couple of questions: Are the mounting holes the same? Is the way of attaching the brakeline the same?
April 27, 201610 yr I am newer to trials and GasGas and do not have experience with older models with Formula brake components. My friends have had trouble with Brakum Teck with metal in the rear master cylinder and cut seals. I have changed to the Jitsie ( Beta style ) rear master cylinder kit for my 2014 GasGas. The Jitsie kit isn't a bolt on deal, you must modify / adjust for alignment. Also I had to take a ball-peen hammer to make clearance for the exhaust. So far I am happy with the performance and hopefully better reliability. This maybe a option for you?
April 28, 201610 yr Author Thanks. i stripped it and took it to the shop. The braketec parts fit perfectly but if you're changing I'd check old against new. Think it was 9.5mm kit. All good now for £20.
