May 7, 201610 yr Hi. I need to replace the front and rear sprockets as they're long overdue. Only problem is I'm having some trouble finding a rear sprocket. The bike is a 1999 contact 200 (which I believe is actually a 160cc) with a 44 tooth rear sprocket fitted which seems quite large (I'm quite happy with the gearing so would rather not change it if poss), my question is do these sprockets cross over with any other models or makes that will make give me more options? As always advice much appreciated. Thanks
May 8, 201610 yr Author Thanks a lot. Manger to find some online now from a Talon distributor. Thanks.
