November 8, 200521 yr does anyone know how much a new airfilter box is for 290 sherco 03-05. the brass inserts in mine are knackered. if so where did you get one from? ta.
November 8, 200521 yr You can make it work for the price of 2 zipties to hold it to the rear fender support.
November 8, 200521 yr Author ta,but all three threaded inserts are split.and the bolts keep coming loose,even with threadlock. i'd rather have the airbox fitting properly like it is meant to. thanks for the advice anyway.
November 8, 200521 yr Try ringing around dealers to if they're breaking any older bikes. Haven springs to mind.
November 9, 200521 yr Had the very same problem not so long ago. Try looking back at old posts on this forum. A new airbox is approx
November 9, 200521 yr Think thats an airbox cover? You could always try the nut things with spikes and some gripfill?
November 9, 200521 yr What's an airbox cover? Just spoke to the bloke selling the kit (James). The rear brake lever has gone (I was after that). The airbox is still there and the brass inserts are perfect, but..the airbox has been modified for a 28mm flat slide carb, although the original stub is there if you want to get it hot welded back. Sorry - didn't check price, but the brake lever was reasonable.
November 10, 200521 yr What's an airbox cover? Just spoke to the bloke selling the kit (James). The rear brake lever has gone (I was after that). The airbox is still there and the brass inserts are perfect, but..the airbox has been modified for a 28mm flat slide carb, although the original stub is there if you want to get it hot welded back. Sorry - didn't check price, but the brake lever was reasonable. <{POST_SNAPBACK}> i ve got a lever you can have i think
November 10, 200521 yr What's an airbox cover? Just spoke to the bloke selling the kit (James). The rear brake lever has gone (I was after that). The airbox is still there and the brass inserts are perfect, but..the airbox has been modified for a 28mm flat slide carb, although the original stub is there if you want to get it hot welded back. Sorry - didn't check price, but the brake lever was reasonable. <{POST_SNAPBACK}> i ve got a lever you can have i think <{POST_SNAPBACK}> Have? That sounds like a bargain PM me a price if you manage to dig it out - Cheers Dabster. Mine has been bent so much it takes me 15 minutes to get my foot on it. Are the Beta rumours true then?
November 10, 200521 yr I will look but I am sure its a good one. Beta is just not for me followed closely by a scorpa (no) then the 4rt(don't think so) which only leaves my favourite the Sherco . OOOh did someone say gasser?
