October 11, 201610 yr I have an Ohlin's rear shock on my 4rt and having just redone suspension bearings it feels as if there maybe a bit of play in the shock bottom bearing. Does anybody have any info on what type of bearing is fitted (rose joint/needle roller/ plain bush etc) and any readily available replacements. I have tried googling but seem to get info for road bikes. motor cross and rally cars etc. Would be nice to have a replacement in my hands before stripping everything down Many thanks
October 11, 201610 yr Double check your bolts? The last time I was on a thread about looseness in rear suspension it turned out he had one of the shock bolts had backed out a bit and only needed to re-tighten them. Don't have an Ohlins on my 4RT so if that isn't it I can't help. Best of luck.
