November 17, 20169 yr Can anyone tell me the diameter of the pistons in the AJP brake and clutch lever assemblies? Also can anyone tell me IF there is supposed to be a thin "washer" under the circlip that holds the pistons in the assembly. Last time I had mine apart I THINK I remember that the circlip ID was large enough to let the piston come out (therefore a thin washer was needed)- but I may not have had the correct circlip??? ANY help much appreciated.
November 24, 20169 yr I can't get a good mesurement on the diameter of the pistons without pulling them apart but I was able to get a good look and I don't see any washer. Looks like this image for parts from what I can see.
