January 21, 20179 yr Hi having just got the bike I can't find neutral bike starts in gear with clutch in gears can be found but not neutral any help would be appreciated thanks Edited January 21, 20179 yr by tribike spelling
January 21, 20179 yr There is no GasGas Pro m/y 2001 Perhaps the neutral detent mechanism on your bike is compromised.
January 21, 20179 yr Sounds like the clutch plates are just stuck. Rock it back and forth before you start it or ride with the clutch in, while braking till the clutch works.
January 22, 20179 yr Most modern trials bikes are difficult to find neutral using the foot, try using your hand. click it all the way down to first gear and then using your hand pull up slowly on the shift lever, you should feel it click in.
