Programming Gear
I'm looking to mess around with different maps in my bike, does anyone know where I can buy the leads / software needed for the job?
Future trials parts sell these but they are expensive.
The software was £40 posted and the cable was about £300.
The map throttle body is about £400.
Im having a play with maps at the moment
Yes I have the throttle body, its a 2017 300rr.
future trials? Have you got a link? Or is it through H&D racing as I know they sell future trials parts
Google "future trials". Its an italian company but you can change the website to english
Cheers for that!
Had a look at there site, the cables don't look complete? How does it plug into the laptop? I don't see any USB or D plugs in the picture or description
Is your throttle body a twin map ? As I heard the software has to be the latest edition for it to work?
2 hours ago, 99techno said:
Cheers for that!
Its a serial connection. You need a pc or laptop with a serial port or get a usb to serial convertor.
Yes my tb is a twin map.
I bought the latest software from them 2 weeks ago
where do you get your maps from? And have you found a fav map? Thanks for your help, have found it most useful
1 hour ago, teddybattye said:
Its a serial connection. You need a pc or laptop with a serial port or get a usb to serial convertor. ...
There's also a later "Setting Tool" (wiring & box) that uses a USB connector. 99techno, you may also want to check Banyeres as a source.
Edited by sportsawyer
Ive been accumulating maps from all over. Im fitting a big bore and termi system so might even tweak a map i have acquired
