February 11, 20179 yr Hi all, I have the following problem, I have a cota 348 which is leaking oil from behind the front sprocket (final drive shaft seal) when it is leaning to this side. The question is how can I change the seal without splitiig the cases ? I have a new seal and hoped to be able to get one or two screws into the seal to pull it out but haven´t had any luck. Is there a better way of getting it out ? It would be a great shame to split the cases for this reason as the engine has had a complete rebuild from the last owner and runs a treat (I guess he forgot to change this seal or it got damaged when doing).
February 11, 20179 yr http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050890.m570.l1313.TR0.TRC0.H0.Xcam+seal+puller.TRS0&_nkw=cam+seal+puller&_sacat=0 I use this to pull the same seal on rotax motors, works brilliantly. (thanks Heath)
February 19, 20179 yr Author I got a different one at the end as I didn´t want to wait for it to come from America ( http://www.ebay.de/itm/Kurbelwellendichtring-Wellendichtring-Simmerring-Auszieher-Montage-Werkzeugset-S-/142282934281?hash=item2120b94809:g:hcIAAOSw3v5YqEup ) which was available localy thisitem is on ebay in the UK as well. Worked just FINE :-)
