199b 340 Exhaust front pipe.
Is the 340 front pipe unique to this model, or is it the same as other 350 models.
The one on my 340 is serviceable but has some dents , I know you can get these out but I'd rather put the money towards a replacement than renovate what I have.
Thanks.
The front pipe of the 199A 350cc should fit too.
The front pipe of the 198A or any 250 does not fit (tried to fit one) as the mounting bracket is smaller and the studs holes in the mounting bracket are narrower.
340 longer?
:stupid: Won't fit been there tried it the B pipe is Longer and the A is shorter there for won't fit the angel off the middle section it different because off the Air box. :stupid:
Get one of these.... ?
Where can you get one?
My dads garage...
 Very nice, clearly a gifted fabricator.
Ill keep my original, opened it up last night and the packing had clearly left the box many years ago, not even a trace of it just lots of carbon deposits.
On 23/2/2017 at 9:28 PM, smelling123 said:
My dads garage...
Would he make me one?
I had to buy a header pipe/muffler for my 199B, bought one from Spain on Ebay from a 199A. It does fit the 199B- no modifications, but I cant be 100% sure it was from a 199A. I would imagine that any pipe from a 199, 199A 0r 199B would fit [the bolt on flange type] even if a little massaging was required, depends how handy you are.
Cheers Greg
Hi Smelling123,
                         that snake pipe on the Bulto gives the bike awhole different look....what did it do for the power delivery?
10 hours ago, bashplate said:
Hi Smelling123,
Hi baseplate,
unfortunately the original pipe was damaged so I had no chance to test them back to back. I got a 2kg overall weight saving with the whole system and I'd guess it gives more low down torque given bigger volume but it's a total guess and I'm probably not a good enough rider to have qualified it better/worse regardless.
not such a big job to make one, it's just 5x 90deg and one 45deg bends from the auction site plus a straight section. An evening with a disk cutter and a mate with a tig welder....
itd be nice if someone did a titanium one...
For what it's worth, I've just fitted my 199a front pipe to my 199b and it's just the same, no airbox issues or anything else.
Can't really see how there would be, after all the only real difference is a slighly bigger hole down the barrel.
While I'm here, does anyone have contact details for the "Owd Codgers" who go round the English autojumbles?. I read somewhere that they make side stands for the 199b .Any info gratefully received.
Many thanks for that, trialsrfun.
