November 22, 200520 yr Just having a nose through the manual and it says 50/50 mix of coolant and distilled water, question is why the distilled water?. Does it make a difference or is it for the protection of the water ways internally? Only looking at it now because its got cold... Richy
November 25, 200520 yr Distilled water has got the calcium removed, so it stops the limescale/calcium deposits building up inside the rad and its associated pipes. This prevents the pipes becoming furred up/blocked and working less efficiently.
November 26, 200520 yr Or you could just buy Silkolene Pro Cool, which comes pre mixed, so you can just pour it in!
