April 9, 20179 yr Any idea on how to pull the headlight out. Looks like 2 clips on each side and it'll slide out, but am concerned with snapping the clips and obviously never finding a replacement. Any hints, tips or tricks? When changing my AAA battery behind the headlight in that black box, I inadvertently pulled a little too hard, and the tiny little frail wires that connect the headlight pulled loose. Need to get in there with a soldering iron.
April 10, 20179 yr Headlight is just fixed with two clips. Just take easy on them and in warmer temperature, so the plastic doesn't snap easily. Headlight and it's wiring is a complete chinash*it (read cheap and fragile), I've broken the wires many times and they self-destruct in time anyway. In the end I just binned it and the dead headlight stays in place just as a design element, rear I just removed, LOL.
April 10, 20179 yr Author anyone know if that AAA bettery needs to be a rechargeable type? I put a fresh AAA back in it, and it starts super easy, then thought maybe it needed to be rechargeable like what was originally in it, so put the original back in, now it takes like 12 kicks to start from cold.. ;(..
April 10, 20179 yr Author 15 minutes ago, canada280i said: maybe the rechargeable ones were flat is this bike super magical and needs a rechargeable? or do you think I could just put another AAA in there?
April 10, 20179 yr I thought the bike was supposed to charge it, but I could easily be full of it. i replaced mine with a rechargeable (after charging the new one). Now I don't worry about it since I have a separate LiPo battery for 'waking it up'
April 10, 20179 yr i dont use a rechargeable anymore, I used to but switched it out for a 9v lithium high power battery which has never let me down yet
April 10, 20179 yr Author so i'll go get a fresh AAA rechargeable just in case that's it, ;).. LOVE the bike.. but takes all the fun out of it when i'm exhausted from kicking it forever. ;).. Edited April 10, 20179 yr by markwoodlief
April 10, 20179 yr I can show you how to do a setup like mine. If you mess up the first kick- this addition (I call it 'super easy start') makes it easy to start anyway. Plus good for troubleshooting.
April 10, 20179 yr Author 4 hours ago, lotus54 said: I can show you how to do a setup like mine. If you mess up the first kick- this addition (I call it 'super easy start') makes it easy to start anyway. Plus good for troubleshooting. much appreciate it.. anything I can bring to the event next month? Besides a case of your favorite beer for helping? Edited April 11, 20179 yr by markwoodlief
April 11, 20179 yr You may want to run a one step hotter sparking plug (4) I set the TPS and idle for Eric some time ago- but if you have any idle issues at all let me know. Mak
April 11, 20179 yr Author 8 hours ago, lotus54 said: You may want to run a one step hotter sparking plug (4) I set the TPS and idle for Eric some time ago- but if you have any idle issues at all let me know. Mak idles good.. bike runs great.. its just the kicking that is killing the vibe.. kicked over a Montesa yesterday that had been sitting for 4 months, second kick cold.. made me really embarrassed when I went over to my bike and kicked it about 10 times before it started.
April 11, 20179 yr With 'easy start' AAA battery fully charged Push kill button once. take slack out of kickstarter, then give it a VERY healthy kick. Don't touch the throttle! Mine will generally start 1st or 2nd kick from cold, 1 from hot. (With my latest map/fuel mixture setting when cold it has been taking a few kicks, but it runs so well when warm I've left it) that's what works for me anyway.
April 11, 20179 yr Author 20 minutes ago, lotus54 said: With 'easy start' AAA battery fully charged Push kill button once. take slack out of kickstarter, then give it a VERY healthy kick. Don't touch the throttle! Mine will generally start 1st or 2nd kick from cold, 1 from hot. (With my latest map/fuel mixture setting when cold it has been taking a few kicks, but it runs so well when warm I've left it) that's what works for me anyway. haven't tried to kick it over with a fresh AAA yet. Going to try that this afternoon after my morning con calls.. thanks for the tips Mark..
April 12, 20179 yr Author 11 hours ago, lotus54 said: With 'easy start' AAA battery fully charged Push kill button once. take slack out of kickstarter, then give it a VERY healthy kick. Don't touch the throttle! Mine will generally start 1st or 2nd kick from cold, 1 from hot. (With my latest map/fuel mixture setting when cold it has been taking a few kicks, but it runs so well when warm I've left it) that's what works for me anyway. put a fresh AAA in it.. Now it's about a 3 kick cold, 1-2 kicks warm start, much improved! Now if I can convince my 16yo to get the hell off of it I can get some practice in. Edited April 12, 20179 yr by markwoodlief
