Txt pro 300 clutch noise?
So I have this problem with my bike. When the gear is on and clutch is distached then I get weird clicking noise. I made a video about it (video is liked end of the post). Can anybody tell me what is the problem with the bike? Does anybody have had the same problem?
https://www.youtube.com/watch?v=U_Xg7p2gMZY
It is difficult to diagnose when the motor is not running. If the clicking noise is there in any gear, or even in neutral with the motor running then it is very likely that the kickstart idler gear has a chipped/damaged tooth or teeth, which would be reasonably common on an older GG Pro motor. Other problems in this area are likely to be the kickstart quadrant, the 5 tooth gear that engages with the idler to turn the clutch gear when kicking over. Have a look on the clutch gear, the basket we call it, to see if any of the teeth are damaged too.
Bye, Peter B.
