‘O’ Ring chain with half link
My 300 evo 4T came with a chain that has a half link.
  I dont’ like non-O ring chains around here- I ride in the wet and mud a lot and I find standard chains wear out very quickly.  I I have used DID VTX2 chains on my OSSAs, they are narrow and will fit with just a bit of trimming on guide.
BUT- they don’t make a  half link for those. If I extend to a full length, the axle won’t go back far enough. If I take the half out- it won’t go far enough forward.
anyon know of a narrow ‘O’ ring chain that has half links?
mark
Yes- I probably could do that, although (so far) I am liking the gearing.   I’ll think about that
thanks
mark
No worries, One tooth difference on rear is gonna be pretty much unnoticeable....good luck:)
I had the same problem on my 2016 4t, i just took a file and removed a few millimeters off the front of the hole that the axle slides in the swingarm. Bike looks good with the gold D.I.D. chain.
I was going to suggest that!Ive had only bad things happen with half links,I think ive got a hatred of them!
