December 9, 200520 yr Advice please Just noticed a slight fuel leak at the rear of the tank on my 250-03 pro, it could be where the seat unit has been rubbing or maybe on a weld. I was thinking of repairing with plastic metal but would welcome other suggestions / advice. Thanks Stormy
December 9, 200520 yr I have just had this problem with my 2004 280 Pro. My dad bought some tank sealer from Frosts, not sure what he did but it has worked. http://www.frost.co.uk/item_Detail.asp?productID=8232 We had previously had it welded.
December 9, 200520 yr I had the same problem my 05 280 Pro. I used chemical metal which worked for a few months and then when it leaked again I simply used the sma e method again. I think a new tank is around
December 9, 200520 yr sealing it from the outside is always eventually going to fail, a commercial internal sealer is a certain fix and if you can get the white sealer, sold by the bike shop in leeds whose name I forget you can very clearly see the level of fuel left in tank, and I used a marker pen on mine so that i knew the exact quantity of fuel in the tank, handy for those premixes that are more guesswork than science , its also very easy to see if you have any debris etc in the tank once done.
December 9, 200520 yr best bet is to get it welded if possible ,otherwise repair with araldite or similar every few months. a new tank is about
December 16, 200520 yr Anyone tryed to figure out what causes the problem in the first place...it would make it easier to get a permanent fix. There must be some stress on the tank from somewhere if it is cracking a weld or rubbing a hole in the metal! where exactly are the leaks appearing. anyone got any photos?? It would be nice to figure out before it happens to mine.
