exhaust o rings
Ive just had some exhaust o rings come as they need changing. Is it recommended to lube them with anything when installing or dry.
i personally used a very little bit of 2 stroke oil just to wet them a little bit to stop the o rings getting twisted as you slot in the exhaust.
Edited by mink_man
all done used a dab of 2 stroke oil and went on fine. one o ring was missing and the other split.
I use a bit of Hylomar. Seems to hold up well and do the job nicely.
