4rt Exhaust Restrictors
just tried to put the middle exhaust restrictor back in my
05 4rt (it was out when i bought it) can someone please confirm
where i should be shoving it, i have tried as the manual shows ie.
in the back box but i felt like it need hammering in, and it was
cutting in to the lining of the back box which i didnt
think was right so i have left it for now, can anyone help !!!!!
B)
it slots into the front of the silencer behind the fibre joint sleeve that the front pipe pushes into
munch does it fit snugley or loosely just i dont like fitting
things with a hammer unless its a must.
is it as the manual shows ?
B)
Edited by jsp
have you taken out the sealing tube? it fits behind that
no hammer required its a honda!
Edited by munch
no, whats it look like ?
is it like a dark grey fibrous material in the back box
neck ?
Edited by jsp
yes pull that out,the restictor goes behind it and is held by it
thanks munch, got the sleeve out with a bit of wiggling and
everything back where it should be.
:D
  • 3 weeks later...
Did you notice any difference (power wise), with the middle restricter in?
I,thought the bike seemed smoother at the bottom end!
with the back and middle ones in it is smoother and alot quiter.
