January 7, 20188 yr I have a standard 2017 GASGAS 300 reiger rear shock on the bike as they come with standard spring think they are for the 60-70kg rider.. however im 100kg and wanting to know Is it worth putting a stronger spring on to be more suitable for my weight. What help/benefits will this make Thanks
January 7, 20188 yr Yes, it is worth everything. You have a new bike, but at your weight the suspension cannot do what it is supposed to do. You are riding a bike that is totally sacked out, no ground clearance and steers like crap. The right shock spring would fix that. PS You should do the front spring too. Edited January 7, 20188 yr by lineaway
January 7, 20188 yr Author Thanks for the reply. i wont loose traction or anything been on a stiffer spring will i? (Less weight on the rear wheel) Will it also come back at me quicker when pushing down on the suspension?
January 7, 20188 yr You will maintain traction better with the correct springs. With “normal” preload your suspension will be too soft so your geometry will be much more variable over bumpy terrain complicating control. If you crank up the preload the suspension will require your weight on it at all times to work as the springs will not compress until you have enough weight to overcome the preload. Up to that point it’s like a hard tail. A heavier set of springs will allow less preload making the suspension work better on smaller surface irregularities while still absorbing bigger hits without hard frame breaking bottoming out. And as Lineaway points out front and rear need to work together. Edited January 7, 20188 yr by dan williams
January 7, 20188 yr Author Thanks dan williams ive got the correct spring for my weight ordered. im guessing when stood on the bike it will be alot stiffer to compress the spring but will benefit me when splatting/hopping as its gonna rebound quicker than the slow standard one i have... correct?
January 7, 20188 yr It will rebound quicker and will have less traction unless you increase the damping to suit
January 7, 20188 yr Yup you might need to go up a couple clicks on the rebound damping but you will have more control on the bouncy chewy stuff. I’ve done the heavier springs with less preload on my Betas for years and it really does help.
January 7, 20188 yr The only thing that a spring will do for sure will give you more usable travel. The rest is up to you. Have fun!
January 8, 20188 yr I've tryed different springs before.the problem i get is you need to do something with the front as you lose the balance of the bike
