January 21, 20188 yr Hello all, I've just managed to find myself a never used 2013.....first day out on it today, in the sleet! Does anybody have the details on what the standard spring weights are? I'm about 80kg with riding kit, even with the preload wound on a bit, the balance wasn't quite right today. Reckon I could probably go up a bit on the rear spring, but could do with some tables/rating info? Thanks, Scott
January 22, 20188 yr Is it the standard shock?Wants to sag about 1/3 of its travel with you standing on it,it shouldn't be far out with your weight
January 22, 20188 yr 80 kg with riding gear? Should be spot on. If its the standard shock (sachs), Its most likely your marzocchis at the front being too hard Edited January 22, 20188 yr by faussy
January 22, 20188 yr If you push down on the seat front and rear should travel the same,you should be able to get it right with the adjusters
