January 22, 20188 yr Hi guys an gals i have a beta evo 300 2t its 2015 what settings should i use for outdoors as in forest ,mountains ,streams etc on my front shocks i got new seals an since done it seems harder to ride im 12 stone etc 5 11 height if it needs be i used 5w oil in them any help wud be brillant or link etc ??
January 22, 20188 yr Did you do the work? It sounds like there is too much oil. Do the forks travel as far as they used to?
January 22, 20188 yr If your forks are the same as my Beta forks, the handbook says that the left adjuster adjusts the pre-load, which for your weight should be 5 turns inwards (10 turns if you are over 80Kg.) The right adjuster controls the damping effect, totally unscrew this for very quick damping. For a more controlled damping turn inwards by 15 clicks (out of the 30 click maximum.) Or adjust for your riding style. .
January 22, 20188 yr Actually the Beta manual gives the settings for your weight, but I question if the forks were done correctly.
January 22, 20188 yr Author 14 hours ago, lineaway said: Did you do the work? It sounds like there is too much oil. Do the forks travel as far as they used to? Hi no i didnt do work but was told that cud be option ??
January 22, 20188 yr Author 16 hours ago, scifi said: If your forks are the same as my Beta forks, the handbook says that the left adjuster adjusts the pre-load, which for your weight should be 5 turns inwards (10 turns if you are over 80Kg.) The right adjuster controls the damping effect, totally unscrew this for very quick damping. For a more controlled damping turn inwards by 15 clicks (out of the 30 click maximum.) Or adjust for your riding style. . Great information the right fork is the clicker correct but the alley key on left seems to be very tight but spanner catches ouside correct an i shud be able twisf it then ..
