January 22, 20188 yr Can someone let me message them of my bike too see if you think it sound right thanks I’m trying too put a video up but it won’t let me cheers
January 23, 20188 yr Strip down time,definitely main bearings ,hopefully big end OK,hard to hear anything else
January 23, 20188 yr Author Yes it was warm before the video could it be jetted incorrectly? And does anyone know a rough cost on doing the main bearings
January 23, 20188 yr You can get it done pretty cheap. Main bearings, main seals, center case gasket, base gasket and intake gasket. Buy the bearings from a bearing supply. Beta used to have a gasket and seal set. Good luck. Cheaper if you just take the engine alone to a shop.
January 31, 20188 yr I put mains in my Techno a year or so back, had mains, seals and gaskets plus a small end, spent around 120 pounds on parts, also bought a cheap chinese puller to get the bearings off the crank for around ten pounds. Whole job took about 6 or 7 hours I suppose.
