Lost me spark
Good evening,help needed please.
i have recently bought a 2007 rev3. Which was running fine till I decided to, chop some of the excess wiring out, which had left me with no spark. Hoping there's a diagram below of what I have!!
Well your schematic matches mine so I'd say go after ground connections and make sure connectors are actually connecting. The automotive connectors sometimes let the pin slip out the back when you push them together after having them apart so they look connected but the aren't. Always the basics first.
Excellent thanks for your suggestions and advice, I will be spending today in the workshop. Hopefully by the time my son comes home from school, we will be going out for a play.
Sorry though I'd replyed already.
started by poping radiator out, to allow me remove CDI and regulator, Brightened checked all connections. filed a small area around the bolt hole on the tripple clamp earth, then ran a spur back to the earth behind the regulator bracket.  Lovley bright sparks !!!!
Thanks everyone.
